Gidday,
A newby from the Antipodies who is on a very steep learning curve.
Fitting the Wabash TPS as supplied with the MJ.
The hole ID on the TPS is 8mm, the OD on the Weber shaft is 6.5mm.
Is there a spacer available or do I make one.?
Les.
TPS fitting
Hello Les,
Here is how I solved it, but you may find ready-made ones (Weber).
Cheers.
Jos
Cheers.
Jos
- Adapter (selfmade)
- axis_profile.JPG (28.59 KiB) Viewed 8365 times
- trial fit
- TPSadaptor.JPG (19.2 KiB) Viewed 8365 times
If all else fails, consult the manual.
My blog: http://jacob-jos.blogspot.com/
lotuselanman
TPS.
Gidday Luxseven,
Thanks for the reply, food for thought.
Travelled through your beautiful country when completing in a Classic car rally in 1999.
Les.
Les.
