TPS fitting
lotuselanman
TPS fitting
Post by lotuselanman »
Gidday,
A newby from the Antipodies who is on a very steep learning curve.
Fitting the Wabash TPS as supplied with the MJ.
The hole ID on the TPS is 8mm, the OD on the Weber shaft is 6.5mm.
Is there a spacer available or do I make one.?
Les.
luxseven
Post by luxseven »
Hello Les,
Here is how I solved it, but you may find ready-made ones (Weber).
Cheers.
Jos
Adapter (selfmade)
Adapter (selfmade)
trial fit
trial fit
If all else fails, consult the manual.
My blog: http://jacob-jos.blogspot.com/
lotuselanman
TPS.
Gidday Luxseven,
Thanks for the reply, food for thought.
Travelled through your beautiful country when completing in a Classic car rally in 1999.
Les.
