RPM problem
Information and announcements on updates to the Megajolt firmware and PC software
dainiux
RPM problem
Post by dainiux »
HI all
The current software is working only on 4,6,8,12 CYLs. But what about 5 CYL (AUDI 100)?
If I turn on megaspark on 5 CYLs and set as it would be on 4 CYLs, then there will be showed even 1000 RPM instead of 800 RPM.
Could the 5 CYLs variant be expected?
Dainius
Oliver Sedlacek
EDIS 5
Post by Oliver Sedlacek »
The megajolt could be adapted easily enough, but you would need a 5 cylinder version of the EDIS coil driver. This would be a problem as the EDIS system is a wasted spark system, which always fires two sparks at the same time.
dainiux
helloI will add logical
Post by dainiux »
hello
I will add logical elements and then outputs will be as needed.
But I am not programmer, so I cannot change software for 5 cyls. If software would work for 5 cyls, then it will show correct rpms and I will be able to change MAP correctly.
Dainius
mikerj
Not suitable for 5 cylinder engines
Post by mikerj »
Megajolt is simply not suitable for 5 cylinder engines in it's current form (i.e. relying on the EDIS system).
