Reply to topic Page 1 of 1
RPM problem
Post RPM problem
HI all
The current software is working only on 4,6,8,12 CYLs. But what about 5 CYL (AUDI 100)?
If I turn on megaspark on 5 CYLs and set as it would be on 4 CYLs, then there will be showed even 1000 RPM instead of 800 RPM.
Could the 5 CYLs variant be expected?
Dainius
Post EDIS 5
The megajolt could be adapted easily enough, but you would need a 5 cylinder version of the EDIS coil driver. This would be a problem as the EDIS system is a wasted spark system, which always fires two sparks at the same time.
Post helloI will add logical
hello
I will add logical elements and then outputs will be as needed.
But I am not programmer, so I cannot change software for 5 cyls. If software would work for 5 cyls, then it will show correct rpms and I will be able to change MAP correctly.
Dainius
Post Not suitable for 5 cylinder engines
Megajolt is simply not suitable for 5 cylinder engines in it's current form (i.e. relying on the EDIS system).
