Nice work with the Race Analyzer 1.17.0, I see that the analog channel manual mapping is now in volts. One small suggestion, when the numbers are typed in to the Volts row, they should be rounded to the nearest quantization.
Now for the bad news, I just found a bug on the configuration part of Race Analyzer 1.17.0.
I was trying to setup a Pulse Input on Channel 2. Selected Frequency Mode with Clock Divider at CLOCK/8 and 1 pulse per revolution. (It's not just CLOCK/8, it also happens with CLOCK/2.)
When I pressed the increment button to increase the logging precision the program crashed. It also crashed when I manually type 2 into the dialog box.
I suppose I must have accidentally selected an invalid configuration, but it would've been nice to get a dialog warning me that the combination I selected is not a valid configuration.
Maybe the problem is that in Frequency Mode only 0 precision is valid?
Config Bug with RaceAnalyzer 1.17.0
- Config_Bug.jpg (42.97 KiB) Viewed 3380 times
