MAP to TPS
Post MAP to TPS
Hi, I have a MAP optioned MJLJ, and I want to change to a TPS option. Can I simply solder in the additional components or do I have to remove the components for the MAP option?
Justin
Yes the instructions are somewhere in here, you can get all the bits needed in the autosport labs shop. Not sure about leaving them in place, but I know you can't use both.
You can safely leave the components in place, just be sure to disconnect the TPS from the molex connector.
Founder, Autosport Labs
Thanks for the reply. I have sorted this out. Removed the 270 ohm resistor from the MAP circuit and added the 7 components for the TPS circuit. Calibrated the TPS, works great.
fantastic. thanks for the update
