MAP to TPS
hillmanwings
MAP to TPS
Post by hillmanwings »
Hi, I have a MAP optioned MJLJ, and I want to change to a TPS option. Can I simply solder in the additional components or do I have to remove the components for the MAP option?
Justin
toenee
Post by toenee »
Yes the instructions are somewhere in here, you can get all the bits needed in the autosport labs shop. Not sure about leaving them in place, but I know you can't use both.
You can safely leave the components in place, just be sure to disconnect the TPS from the molex connector.
hillmanwings
Thanks for the reply. I have sorted this out. Removed the 270 ohm resistor from the MAP circuit and added the 7 components for the TPS circuit. Calibrated the TPS, works great.
fantastic. thanks for the update
