Coil pack
S123fty
Coil pack
Post by S123fty »
Hi all.
I have a megajolt junior lite. I have wired the system up as per the diagrams I have but I cannot get a spark. The next step I'm going to try is swapping the vr polarity. I'm a bit confused as I have a 4 cylinder engine but the coil pack has 4 pin connection and not 3. Is one of these spare?
Running a vauxhall x16xe engine
Did you figure it out by swapping the VR sensor?
You may have a dual coil pack with independent connections, where one of the connections wires to a common 12v power source, giving the effect of a single dual coil 3 terminal pack.
parky1972
Post by parky1972 »
Vaxhaul coil pack is 4 wire.
12v, earth, coil 1 & coil 2.
Make sure these are wired correctly otherwise you won't get a spark.
Try connecting the earth and see what happens.
Failing that. Use a ford coil pack instead.
Jason.
Worth noting - if the coil pack has an explicit ground connection then it is likely an active coil pack with a built in transistor driver ("igniter"). You'll want to go to a standard coil pack, like the one provided by ford in the original EDIS systems.
MrDangerUS
Post by MrDangerUS »
Don't use any black aftermarket coils, no matter how well they are advertised. They burn out after couple of weeks/month, non-reliable junk.
I was advised to use Red MSD coil PN# 8241 instead.
The aluminum base does not come w/coil. It is a Millers Mule Machine part made specifically for Lotus 910 Engines. http://www.manta.com/c/mmn4g16/millers- ... and-design
Mr. D
Extreme Esprit Turbo X330,
http://www.thelotusforums.com/forums/garage/
