Celesco SM1 12" cable won't retract
turtlesharkshooter
Post by turtlesharkshooter »
Can I take it apart and reset the tensioner?
turtlesharkshooter
Re: Celesco SM1 12" cable won't retract
turtlesharkshooter wrote:Can I take it apart and reset the tensioner?
I gambled and took the unit apart.
#01 I'm talking about this guy.  I somehow broke the tensioner.
#02 Used a T5 torx driver and this is what I saw once I split it in half.
#03 What happened is the spring somehow disconnected from the shaft.
Last edited by turtlesharkshooter on Tue Jan 03, 2017 9:36 pm, edited 2 times in total.
turtlesharkshooter
Part II
Part II of the rebuild.
#04 The goal was to get the end of the spring back into the slot.  I lined them up like this and got the blade back into the slot.  Once the 2 halves were sandwiched together, I rotated the top half till the cable retracted all the way up.
Oh no! was it like that as new, or did something happen to prevent it from being able to retract?
turtlesharkshooter
brentp wrote:Oh no! was it like that as new, or did something happen to prevent it from being able to retract?
I was checking the range and felt the unit shimmy and spring release then no tension. It was very easy to fix. Ive gotten in 6 runs and unit is performing as designed.
That's good to know it's a recoverable situation. :)
