Updated OBDII mapping guide for standard and extended PIDs
Post Updated OBDII mapping guide for standard and extended PIDs
We have a vastly expanded OBDII mapping guide which will show you how to map standard and extended (Mode22) PIDs. Check it out here:
https://wiki.autosportlabs.com/RC_OBDII
Please let us know here how it works for you, and if we've missed anything.
Thank you,
Copying a question I posted on your FB page:
Can I get some help trying to get extended OBDII working? Ford Focus RS and trying to get TPMS data.
It works correctly with Torque using their default setting: PID 222813, equation (((256*A)+B)/3+22/3)*0.145
I'm using OBDII PID 10259,22h, CAN ID 2024, Offset 4 length 2 unsigned, big endian
I've also tried 29bit mode.
How do I debug this? I get no data (only 0's) I also see something about squelching that channel in the Info log. Not sure what that means.
Digger deeper, maybe I need to set the OBD header? In Torque it's changed from the default to 726 (hex I think). I don't think we have the option to change that in RC.
Hi, can you post a link to the torque docs that show how the header is changed? We'll see if we can adapt it.
Of course I can't find any documentation on the Torque Pro extended PIDs.
It just says it has a header of 726. Other header values I've seen are "Auto" "ABS" "TCM" and blank.
Another value I've been sort of able to retrieve had a blank header, but the data received didn't match the expected values, but it sent back something.
Is there a simple lua script to send something out and monitor what comes back?
Here's are two examples of manual OBDII querying:
https://gist.github.com/brentpicasso/ed76d612be30edfb3f9b4336a3588424
https://gist.github.com/brentpicasso/7a11e385460bf02c5ec3ce6c70024041
You can see how the request / reply works. Not sure what Torque means be "header" - if you can clarify that we can understand where it fits in the standard OBDII query / response.
Let us know what you find out. Thanks!
While I look at that lua code... here's another post on another forum that goes into more details about the exact PID I'm looking for.
https://www.clublexus.com/forums/is-2nd-gen-2006-2013/885826-custom-pid-for-tpms-read-out-on-torque-pro-app-with-obdii-eml-327-reader.html
