1275 mini / metro map?
Well im in the process of fitting megajolt to my mini, it has a standard 1275 metro engine in it at the moment, so does anyone have a mat that will get it running well, i dont plan to be running the engine for very long, but i just want something that will get the engine running well.
try starting with the aldon yellow one http://www.autosportlabs.org/viewtopic.php?t=1643
I think that would be the closest at the moment that can be found on here. All i have done with mine so far is get a map off here with an engine of similar spec and then have a play around with it. Mainly to get it to idle properly with the correct fueling.
Hope this helps
Ryan
Hope this helps
Ryan
If I've done it right, this is what I have on my almost standard 1380 A+. Drove it today for the first time and it goes well, although I haven't explored the higher regions yet.
- Midas1.mjlj
- (717 Bytes) Downloaded 1511 times
Geoff
