1275 mini / metro map?
Tomf
Post by Tomf »
Well im in the process of fitting megajolt to my mini, it has a standard 1275 metro engine in it at the moment, so does anyone have a mat that will get it running well, i dont plan to be running the engine for very long, but i just want something that will get the engine running well.
Post by NITROPIXIE »
try starting with the aldon yellow one http://www.autosportlabs.org/viewtopic.php?t=1643
I think that would be the closest at the moment that can be found on here. All i have done with mine so far is get a map off here with an engine of similar spec and then have a play around with it. Mainly to get it to idle properly with the correct fueling.
Hope this helps
Ryan
h4887
Post by h4887 »
If I've done it right, this is what I have on my almost standard 1380 A+. Drove it today for the first time and it goes well, although I haven't explored the higher regions yet.
Midas1.mjlj
(717 Bytes) Downloaded 1511 times
Geoff
