x-flow 1300 Map
thepest
x-flow 1300 Map
Post by thepest »
Here is my Map that I used on my 1300 xflow in a locost
3d map-locost1300.mjlj
My Map for a 1300 xflow with a GT cam, webber 40's. Everything else is standard.
Uses regular fuel
(719 Bytes) Downloaded 1147 times
Here is the performance Graph of a run down a 1/4 mile strip
x-flow 1300.jpg (128.51 KiB) Viewed 10802 times
John_S
Post by John_S »
i've been asked to set one of these up for a customer (i usually do megasquirt so i'm ok with this stuff)
so i borrowed ya map with a few changes all seams ok but were down on power compared to a when it was running a dissy only by 10 bhp or so. just wondered if u knew of any other things we can do ....?
or is this the case with mega jolt ..... lose a bit on the top end but get better driveability
wonderfulweasel
Post by wonderfulweasel »
Do you have any more info on the spec of the engine you're trying to set up?
What carbs? What cam? What exhaust? Has it had head work? etc.
This may make it easier to advise.
