No LED
Phaeton
No LED
Post by Phaeton »
After about 12 months I dug my megajolt out of the cupboard. Couldn't remember where I go to, so re-tested all the voltages & all was okay. Fitted the IC's & connected it to my PC & power source on the bench, the LED does not light up but there is 4.98V across the terminals of it. The KPa is twitching & if I suck on the MAP sensor the needle swings round.
Is it likely that the LED has just blown or is there likely to be another problem somewhere else?
Alan..
Try re-soldering the LED joints- if that does not work, try replacing it with another T-1 sized LED. you should be able to bend the leads so it still fits in the plastic carrier.
