I'm about to put the MegaJolt EDIS into my car.
I have planned to put some fuses and a relay in.
What values of fuses should I use ?
Please have look at my sketch.
Values for fuses recommendation
- Sketch EDIS.png (188.32 KiB) Viewed 21282 times
One reason is, I have this nice little holder for the relay.
The other reason is, I can distribute easily the power from one point
to the four devices. Two coil packs, EDIS module, and MegaJoltBox.
How do you connect four wires to one wire ?
For earth distribution I will use this:
I got this from a VW mechanic.
- IMG_0980.jpg (100.17 KiB) Viewed 21265 times
- IMG_0981.jpg (137.68 KiB) Viewed 21265 times
My supply wire is 14 AWG which connects to a 14 AWG wire to the coil packs and two 16 AWG wires that go to the EDIS module and the MegaJolt. I simply connected them all together with a parallel crimp splice (not a butt splice), soldered the ends and covered with heatshrink tubing. That's also the method I used to connect the EDIS and MegaJolt ground wires to the 14 AWG ground wire I have coming directly from the battery (-) cable. I don't like to use any more terminals and connectors than absolutely necessary, just more connections to cause problems.crossflow wrote: How do you connect four wires to one wire ?
I don't like to use any more terminals and connectors than absolutely necessary«
I totally agree with your statement.
I just could leave two slots for the fuses empty.
Are the wires all on one side of the parallel crimp splice ?
I am confused about crimping and soldering.
I am used to crimp or solder, but not both.
The wires can enter one side of the splice or both sides, doesn't matter since they all get crimped into a solid mass. Soldering the ends of the splice is just a way of sealing the connection from the environment. Also it's sometimes difficult to hold together several thick wires while trying to solder them together. Use the parallel splice to hold them together and then solder. My company builds wiring harnesses, some are for automotive use. Some of our automotive customers require that we solder seal crimped connections that will be located outside of the passenger compartment. Technically speaking, if the crimping is done correctly and provides a gas-tight connection it shouldn't be necessary. I guess they like the added insurance. I've just gotten into the habit of doing that.
i agree with a single 20A, or just put 10A fuses in your 3 fuse holder. all said and done, they are there to protect your wires from burning due to a dead short. even wires not rated for 20A will survive the brief amount of time it takes for a short to blow a 20A fuse. so it isnt really a critical thing.
alexander.
alexander.
Not Anumber
The Megajolt is low current so should be on a separate low-rated fuse, 5Amp is overkill for that really. The EDIS and coils are the bits that needs the higher current fuses. In general people connect both EDIS and coils to a single fuse, 10A should be fine on a 4-cylinder setup but with dual coils I'd probably go out to a 15Amp fuse.
www.trigger-wheels.com
