Older Smiths Tachs etc not working Solution Found :-)
Josh_b
Post by Josh_b »
i sorted it, i made a little circuit up and just tested it, i tried a smiths tach and a vdo tach and they both work fine! if anyone is interested i will sort out a circuit diagram, it basicly converts the MjLj RPM output into a signal older tachs can use :-)
mini1071s
Smiths Tach circuit
Post by mini1071s »
Well done for sorting that out! Could I have a copy of the circuit please? Thanks.
[email protected]
Josh_b
touch wood!
Post by Josh_b »
hehe, i put the diagram in the files section, I just added a much simpler version also thatstill seems to drive smiths type tachs from the MJLJ output
mini1071s
Post by mini1071s »
steve_c
Post by steve_c »
I'm interested in this., but can't find the files section!! can someone direct me?
dave9469
Post by dave9469 »
Steve
I think this is the diagram Josh made but I don't know if there have been any updates to it, it says it's version 2.
If you use it let me know because I'm intending using a smiths gauge from a scimitar.
Dave
It's important to note- this circuit was designed to accommodate the MJLJ V2/V3 design; In MJLJ V4 the TACH_OUT circuit was changed to essentially the same circuit as Dave posted.
Gilesy998
Post by Gilesy998 »
Is this meant for the RVC voltage-sensing type tachos? ie where the original coil -ve would simply have been connected to the tacho's singal input, rather than the older loop-through style RVI inductive sensing type?
steve_c
Post by steve_c »
At a guess I would say this was for the RVC type tacho's. Mine's an RVI. The current handling capacity of the BC108 is only 100mA so I would guess that this would burn out if connected to the RVI. I don't know the impedance of the RVI tacho so can't say for certain. I will do some checking over the weekend. I don't particularly want to spend out for another tacho if I can get away with a simple high current switch.
Josh_b mentioned in one of his posts that another member (lotus68racer?) had "run the 12V common lead to the coils from the tach", thereby running the coils primary current through the tacho in a similar manner to how the RVI tacho would have worked in a distributor system. Does anyone have any further info on this mod?
