My Megajolt Lite Jr has a 9 pin outlet for connection to the computer. What to do now that my new computer has no 9 pin connection anymore? Only 15 pin, USB and other "flat connectors". Are there adaption cables, or?
Otherwise 0 problems with my 8 year old Megajolt!
Robert Verhey
Connection cable between controller and computer
robert verhey
Comms problems
I am now at the point of hooking up my computer to my Megajolt. I finally got MS to acknowledge the port but now having problems trying to communicate with the MJolt. The errors are: Time out occurred and Communications Time Out occurred.
Question: My computer only has USB connections, so, do I need a smart USB cable (one with a chip in it) or make a direct wire USB to the RJ-11 jack?
I have the DB9 to RJ-ll adapter I purchased from you but need to convert to USB.
If I must make the cable or buy a direct connect cable like the one you offer, is there a software driver available?
If it is a direct connect, what is the data rate and other parameters used on the Mjolt serial port??
Doug
Doug
brentp wrote:Sounds like a version 3 controller, with the 9 pin plug on the enclosure? In which case, that's a standard 9 pin serial connection. You can use a USB to Serial cable which will have the correct cable connection.
Let us know if you're still stuck and we can provide links for you.
You will need a USB to serial adapter to go between your computer and the RJ11 cable we provide.
https://wiki.autosportlabs.com/MJLJ_V4_ ... erial_Port
A good quality unit is recommended - you can find them on Amazon or we have one in our online store: https://www.autosportlabs.com/product/c ... l-adapter/
Brent,
Regarding your USB adapter, does it come with driver software?
Doug
Doug
brentp wrote:Hi,
robert verhey
