4AC on Megajolt
84hachi
4AC on Megajolt
Post by 84hachi »
Hi guys! I own a 1984 Toyota Corolla Sport SR5 (AE86) with a 4AC that I successfully adapted Megajolt to a year ago. I used 2JZGE coils instead of the Ford coil. I couldn't find a decent place to put the Ford coil. I made it PnP with the factory distributor connector. Tach works. Trigger wheel is made by Techno Toy Tuning, mounted to their single belt pulley for a 4AGE. Carburetor is a Weber 38 DGES with an internal air horn.
Base map has been good to me, though I'm gonna have to write something with the 284F high lift camshaft and aluminum adjustable timing gear that will go in. So, expect a lot of questions in the coming weeks.
Current status of my 4AC.
2JZGE coils and wires.
SAM_0705 - Copy.JPG (243.06 KiB) Viewed 22518 times
Techno Toy Tuning 4AGE crank pulley with their Trigger wheel, Ford Escort Crank Sensor
edis2 - Copy.jpg (126.01 KiB) Viewed 22518 times
The 1st ever EDIS 4AC is all mine.
Super clean install! thanks for sharing :)
