If I want to output the GPS speed from the Racecapture to a megasquirt how would I do that?
Is there a even can output from racecapture? If so does anyone know the info the megasquirt should "listen" for.
Outputting gps from Racecapture to Megasquirt.
Canyonfive
RaceCapture can output CAN data using the on-board Lua scripting.
The functions for sending CAN data is documented here:
https://wiki.autosportlabs.com/RaceCapt ... out.5D_.29
There's another example here that shows how to broadcast GPS and IMU data:
https://gist.github.com/brentpicasso/0c ... e80c86694c
Hope this helps!
Hope this helps!
