damaged coil pack?
damunk
damaged coil pack?
Post by damunk »
Megajolt and edis 4 were running absolutely spot on until i decided to replace the starter motor.
i forgot to take off the negative battery lead off and when removing the old starter motor (some wire; it was a bit dark) touched the engine and the starter motor started spinning (wasnt engaged in flywheel) and sparked; white smoke. it was about 1 second this happened. installed new starter motor.
since this im getting no spark from coilpack.
i get 12V from pin 1 & 2. when turning on ignition it's still live although it does drop to 11.6V but it always has done and i'd always get spark.
So i know my wiring is okay. I just changed a starter motor. Nothing else was touched!!!
What other tests could I do please?
p.s the sparks plugs were new but were flooded with fuel when cranking so i have cleaned them.
Possibly the EDIS module was damaged during that incident. Could try swapping in a spare as a test.
