Problem staying connected to Podium
csinasac
Post by csinasac »
I have a RaceCapture pro MK3 with 2 displays connected in my E36 racecar:
1) Raspberry Pi (no GUI installed) connected via USB (gauges)
2) Amazon Fire connected via blutooth (lap data)
I have a wifi hotspot in the car and one in my shop for troubleshooting purposes.
I am having difficulty maintaining a continuous stream of data to podium. My preference is to stream from the Pi but I cannot get it to stream (if I could, I would disconnect the Fire from wifi) to avoid a conflict. When the Pi boots and runs the racecapture app, it flashes “podium disconnected” and then continues on. Given that I do not have a GUI installed it is difficult for me to determine if the Pi is even connected to wifi network even though I know I have it configured to.
I can get the Fire to stream to podium but it will stop after 5 or 10 minutes with no indication that it has stopped or why.
Suggestions?
You will need to ensure only one device is set for streaming to Podium. If there are two devices, then podium will continuously disconnect the old connection when the new connection attaches.
As a test, try to stream via the fire tablet only - ensure the app setting for sending telemetry is turned off in the Pi dash.
Hope this helps, let us know what you find out.
csinasac
Post by csinasac »
The fire tablet streamed fine for about 6 hours so I will stick with this for now. Thanks Brent.
Glad you got it figured out. Thanks for the update!
